Canon iR3045N
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    Canon iR3045N
    Canon iR3045 temperature up to 250 degrees. I change fixing assembly, DC Controller PCB Controller and MAIN POWER SUPPLY PCB ASSEMBLY finish.
    Please suggestion for me.
  • kuby
    • Oct 2007
    • 1409
    Re: Canon iR3045N
    Are you talking 250 degrees C or F?
    Startup Performs the temperature control at 220 deg C for 10 sec.
    • copier tech
      • 8172
      Re: Canon iR3045N
      Are you getting an error code?
        • Dec 2007
        • 71
        Re: Canon iR3045N
        It,s Fix E.
          • Dec 2007
          • 71
          Re: Canon iR3045N
          No error codes.
          • teckat
            • 16083
            Re: Canon iR3045N
            It,s Fix E.
            imageRUNNER 2230 / 2230G / 2270 / 2830 / 2870 / 3025 / 3030 / 3035 / 3045 / 3530 / 3530G / 3570 / 4570
            The Fuser Temperature remains high. In Standby Mode the Fuser Temperature shows Fix-C 228c, Fix-E 211c.
            The temperature does not drop. The Fuser unit has been replaced and error history does not show any Fuser Errors.
            Solution :
            In this case doing a DC Controller Clear and re-entering the door specs resolved the problem.
            Service Mode > Copier > Function > Clear > DC CON > OK
            • copier tech
              • 8172
              Re: Canon iR3045N
              No error codes.
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5015
                Re: Canon iR3045N
                So true
                  • Dec 2007
                  • 71
                  Re: Canon iR3045N
                  Originally posted by zoraldinho
                  So true
                  I will follow one more time.
                  Thank you very much good advice from all of you.|
