Printing Problem using Canon IR Advance 6055
  • 813200217
    • Oct 2014
    • 53
    I have two computers
    one is Using Windows 7 32 bit
    The result = everything is fine
    the other is using Windows 7 64 bit
    There is something wrong with the graphic document
    using the same printer driver
    Canon generic plus ufr II
    for example:
    first computer
    pdf document
    word document
    second computer
    pdf document
    word document
    the same document pdf and word document
    Any solution?
  • Canuck
    Tech Specialist
    • 1713
    Re: Printing Problem using Canon IR Advance 6055
    Don't use the generic driver for starters. And make sure its the proper version(32 bit vs 64 bit). Print the documents as imsges
    • 813200217
      • Oct 2014
      • 53
      Already use the proper version (64bit) (if you install the wrong version, the computer automatically reject)
      Adobe acrobat reader (print the documents as images, Already use)
      I also try to share printer from the computer OS 7 32 bit that work perfectly
      I print from OS 7 64 bit using that shared printer, but also has the same problem
      • petermays
        • Mar 2017
        • 91
        hi..try a clean driver install and download the driver from the canon site then install from file.
        if its shared is other pc with win 7 64 bit OS working fine?
        i always try a clean fresh install if i suspect driver.dont use driver you have.download it.
        • copier tech
          • 8202
          Try the PCL6 driver on the 64bit machine
          • 813200217
            • Oct 2014
            • 53
            PC with windows 7 64 bit share canon IR advance 6055
            The other PC with windows 7 32 bit print using that shared printer
            Working fine and perfectly..
            what a strange problem,
            I already try a lot of printer driver with windows 7 64 bit
            same problem.
            i think the only solution is to reinstall with win 7 32 bit
            i forget to tell, i have 3 copier machines, canon ir 6570, ir 5075 and ir advance 6055
            same problem if i print using PC win 7 64 bit.
            • Shoma
              • Aug 2013
              • 2
              Print Test Page from driver to see is it a driver problem or software. Why you share printer that have network? Do not use generic driver, download UFR II Printer Driver V30.30
              • guitar9199
                • Sep 2016
                • 1100
                PCL6 Might not work if the customer didn't order the PCL License. Canon has UFR II installed, but PCL and PostScript are "Add-on's".
                • guitar9199
                  • Sep 2016
                  • 1100
                  +1 on the Model Specific UFR II drivers. Generic might give you strange print issues, or even not let you use some of the machine accessories.
                  Download driver from here (USA)
                  imageRUNNER ADVANCE 6055
                  • 813200217
                    • Oct 2014
                    • 53
                    Problem solved a little
                    I delete all my canon copier machines driver (ir 6570, ir 5075, ir advance 6055)
                    Restart the PC
                    install driver for Ir Advance 6055
                    using UFRII_V30.30_Set-up_x64
                    Restart
                    Try printing using Acrobat reader
                    The result is better but still something wrong
                    Try printing using Word
                    The result is ok
                    • spectraindo
                      • May 2008
                      • 313
                      Restart the PC
                      Restart
                      [ATTACH=CONFIG]40840[/ATTACH]
                      The result is ok
                      [ATTACH=CONFIG]40841[/ATTACH]
                      Try using another version of Acrobat Reader.
                      • guitar9199
                        • Sep 2016
                        • 1100
                        Actually before you do that, try this instead.....
                        Click File>Print, then click the "Advanced" button and put a check mark in the box labelled "Print as image", and see if that makes a difference. It might ALSO be an issue where the machine just doesn't have the fonts available to reproduce that document properly. Depending on what was used to create the image (Adobe Publisher?), you might want to try a different font in the areas that are missing.
                        Case in point... I had a customer creating a PDF brochure, and they were using a "non-standard" font in part of the page. Using the UFR II drivers, that font wasn't available so it selected "Wingdings" as a substitute. (Customer called it "Heiroglyphics"...LOL!) We switched them over to a PostScript driver, and everything worked after that. Find out if that machine has PostScript installed, and maybe try that driver instead?
                        Good Luck!
                        • 813200217
                          • Oct 2014
                          • 53
                          I can not solve this problem,
                          the document i print (via pc that has Windows 7 64 bit) can not be used , it has a lot of mistakes.
                          i give up,
                          i will try instal using windows 7 32 bit.
