canon ir2200 registration off
  • garrycmsi
    • Jun 2015
    • 22
    [Misc] canon ir2200 registration off
    I have a canon ir2200 and the registration is off by about 1.5 inches usually in the morning from both paper trays. it usually happens first thing in the morning but not every time? any ideas would be a great help.
    THANK YOU
  • Brian8506
    • 1664
    Re: canon ir2200 registration off
    Sounds like a registration clutch problem
    • teckat
      • 16083
      THANK YOU
      What direction ?
      Paper Feed
      or Cross Feed😱
      • garrycmsi
        • Jun 2015
        • 22
        Thanks for the input it is off the feed way and i believe it has a registration motor
        • jper34
          • Sep 2011
          • 225
          for some reason I recall a paper guide on the side that breaks, and the
          feed roller shaft flops around. If that is the case, I remember an after market leaf spring you could install..and it worked..check the feed roller shaft on that side...good luck!
