IRA C2225 E020-0160
  • Brian8506
    • 1664
    IRA C2225 E020-0160
    Black drum needs to be replaced due to quality. When I replaced it I got this code. When I put the old drum in its fine. Manual refers to this code as a magenta issue. Any thoughts? I didn't have a second new drum
  • tech28
    • Jun 2013
    • 434
    Re: IRA C2225 E020-0160
    If after market drum, possibly bad chip. Have had issues in the past with after market drums in 5240/5250's, wierd error codes, nothing pertaining to what was done, just off the wall errors. Reinstalled old drum and it's ok, like your problem. Change chip or transfer new parts to old unit.
    • Brian8506
      • 1664
      • tech28
        • Jun 2013
        • 434
        Also, there is a procedure on how to set drum counter to whatever you want, any copy count, so there won't be a message that says replace drum.
        • dan7777
          • Dec 2012
          • 680
          I found out if you do a dcon backup, clear and restore it that message goes away. I think the real fix is to clean the laser mirrors. Not a big job to take laser out. Just make sure it seats correctly when you put it back in. I had many of those machines and only one gave that code every time I replaced the black drum. It eventually did it for the color drums so I cleaned the laser mirrors.
          • nicknt82
            • Nov 2011
            • 155
            Replace old chip Drum back and clear counter Drum service is the fastest way.
            • copier tech
              • 8131
              By default this series does not display "replace drum message"
              • copier tech
                • 8131
                This is the answer, clean patch sensors & fit the new drum back. If the error returns remove & clean the laser ass'y & mirrors this has to be spotlessly clean!
                Swapping the drum chip is a quick fit but it will shorten the life of your new drum.
                Also update the system software this alone may resolve your issue.
                • nicknt82
                  • Nov 2011
                  • 155
                  In This model, Life of drum is very low event replace new drum correctly way. Clear Drum Counter than Drum Chip will be like new one
                  • JPiek
                    • Oct 2014
                    • 435
                    I wonder if you'll notice the diference on the black drums, they hardly ever make it to 100%, you're Lucky if they manage to get to 80% w/o faillures..
                    And yes, clean laser and patchsensors, then just swap the chip if that fails... I've seen al lot of these errors, some drums do give the error, some don't. The word 'Intermitted' was invented for this i think
                    Johan
                    • Brian8506
                      • 1664
                      • roho
                        • Mar 2009
                        • 844
                        Seems odd at first, however I have had some of the smaller Canon color machines printed faded on all colors though much worse on K. Replacing the K drum brought everything back. Will have to read up on how the ATR and Autograd work obn this model.
