I have ira c5035 error code E000027-0400 developer drive coupler is good "new style" I also got a e000025-120 as i was working on this any ideas?
Thank You
Thank You
E027 | 0400 | 05 | Title | Error in supply with Bk Developing Assembly |
Description | Failure in detection about the changes of ON => OFF => ON with the sensor which detects a full rotation of the supply screw within the specifed period of time. |
Remedy | 1. Check the damage of the Developing Coupling. If it’s damaged, replace the Developing Assembly. 2. Check the damage of the coupling (with the Developing Assembly) at the Host Machine side. If it’s damaged, remove the Main Drive Unit to replace the coupling. 3. Turn the motor as a single unit while the Drum/Developing Assembly is removed to check rotation of the Main Drive Unit. If it does not rotate, replace the Motor. If the above measures do not solve the problem, replace the Drum Driver PCB (UN4). If there still remains the problem, replace the Main Drive Unit. 4. Remove the Hopper Unit and manually turn the Supply Input Gear to check rotation. If it’s results in NG, replace the Hopper Unit. |
E025 | 0120 | 05 | Title | Y Mismatched phase |
Description | Set-on Unit detects opening of the Y Toner Container as well as the Small Door. |
Remedy | 1. Check if the Small Door can be closed. 2. Close the Small Door and turn OFF and then ON the power to check recovery. 3. Check the installation of the Open/Close Sensor of the Small Door (to see if it’s installed at the correct position). 4. Check the Sensor Harness (to see if the harness is caught, disconnected or physically removed). 5.(If the above measures do not solve the problem,) Replace the Drum Driver PCB (UN4) |
