E248-0001
Re: E248-0001
Hi,
I have found this:
1- Service mode > COPIER > FUNCTION > CLEAR > R-CON (RAM clear of CCD unit (CCD PCB)) >
2-Turn OFF and then ON the main power switch, and
3-In service mode, enter reader values.
I hope it will help.
Rachid
"Find a job you love and you’ll never have to work a day in your life." Nagy's father -
Re: E248-0001
After re-entering values>Are the CCD Values dropping to "0" after code
Level 1
Copier > Adjust > CCD
I would be careful in swapping Main 2
Had success in replacing Main 2 for exact code.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
