Yellow Drum Unit Problem
  • Andyboachie
    • 185
    I am working on IR Advance C5051 I receive a streak at the edge of the paper. I receive a yellow streak at the edge of the paper. The attachment explains it. If all else fail, i intend replacing the yellow drum unit. But until then, I wish I could get a suggestion on the exact trouble with the unit. this streak also appears on the ITB and the transfer roller.
    I will appreciate any suggestion
  • JPiek
    • Oct 2014
    • 435
    Re: Yellow Drum Unit Problem
    What's the life % on the Yellow drum ? Have you inspected the yellow drum Visual yet ? It does look like you have some defect on the drum..
    Johan
    • rayjeek
      • Jun 2010
      • 239
      Dirty laser slit glass. Clean with the glass cleaning rod.
      Sent from my SM-G901F using Tapatalk
      • roho
        • Mar 2009
        • 844
        Dirty laser leaves a void area, not a streak of the color in question. Change the drum.
          laser slit will not cause a streak... but rather a void instead.. the problem is in the PCU/Drum unit
          • guitar9199
            • Sep 2016
            • 1100
            Color drums are rated about 85K on this series. Much lower if you're using a generic toner. If you're above 80K on the color count, I'd definitely check the drum unit. Since the color drums are interchangeable, swap it with the Cyan drum and see if the yellow streaks follow the drum. If the streaks are still yellow, you likely have a bad developer unit... if the streaks turn blue, it's the drum.
            • copier tech
              • 8174
              Swap the yellow drum with say the cyan if you then get a cyan line you know its the drum.
              • Andyboachie
                • 185
                Hi guys,
                I'll try as you suggested. I think you're on point.
                • Andyboachie
                  • 185
                  Originally posted by Andyboachie
                  Hi guys,
                  Hello,
                  It turned out to be the drum as you suggested. It's great to have you guys around here!
                  Thank you.
