hello again fellow techsters
error E027-0300 is showing on this machine after i replaced 4 DCB's and 1 ITB blade (performed full gradation and test prints OK)
i've read the other threads on this, but still need assistance
neither the coupling on the Cyan dev unit nor drive side are broken, dev and drum both rotate fine, normal resistance - marked the drum and dev coupling with black marker to ensure they're both rotating and the marks had moved, cleaned ITB sensors, but error comes up immediately on reboot
client said that the machine recovered twice, printed half a dozen pages then threw the error again and one time it said cyan toner low for a moment before throwing up the error again
any thoughts? possible cyan toner supply problem? i didn't have time to manually add Cyan toner to see if that got the ball rolling, but the cyan dev looked about right
also, i've forgotten how to open the toner door when it is not asking for a new toner
thank you
thank you
