whites lines occur in my ir 6570
  • AIT MAMEUR
    • Jun 2008
    • 59
    hello.
    i'am facing a problem with my ir 6570. please help me.
    Re: whites lines occur in my ir 6570
    Originally posted by AIT MAMEUR
    hello.
    [ATTACH=CONFIG]41069[/ATTACH]
    invalid link..
    re-post in a valid format
    what have you done?
    is this on prints/copies/scans?
    clean laser lens
    what is the life on parts ( drums/belt/fuser )
    you want help but don't really explain what HAS been done. As a tech ( much like a DR. ) we NEED more information to be able to assist
    • copier tech
      • 8172
      hello.
      Most common cause it coronas, remove & clean them. Replace or rewire if you cant clean.
      While you're removing them pull out & clean the last glass.
      • AIT MAMEUR
        • Jun 2008
        • 59
        I'm sorry dor a link.
        • AIT MAMEUR
          • Jun 2008
          • 59
          I've changed the corona wires and the developping assembly but still the same problem.
          • guitar9199
            • Sep 2016
            • 1100
            [ATTACH=CONFIG]41072[/ATTACH]
            Almost looks like a depleted/starved developer to me.
            • AIT MAMEUR
              • Jun 2008
              • 59
              I don't think that is a developping assembly because it looks good .
              • kuby
                • Oct 2007
                • 1409
                The black shading areas look like the drum needs replacing.
                • Brian8506
                  • 1665
                  Arcing corona maybe. Did you do the transfer separation corona?
                  • guitar9199
                    • Sep 2016
                    • 1100
                    I'm not sure what the spacing is between the blank areas, but it almost looks like there's no developer in one spot on the rollers. I'm going under the assumption that the paper is feeding in LTR format... in which case those void areas would be rotational.
