HELP PLEASE!!!
+ More Options
Posts
  • Ariflakhani
    • Jul 2025
    HELP PLEASE!!!
    I have just opened a small printshop today and have purchased a canon irc3380i...the spec says u can print stock upto 220 gsm the local tech said u can go upto 250gsm but i have a client who needs business cards on 300 gsm?Also am having difficulties in getting the correct or even nearest PANTONE shade am struggling in getting the colors right.
  • BLITZKREAGG
    irc 3380i
    as for the color issue have you done a full auto gradation in service mode
    AF 28 AF > cleaning, adjustment, > Auto gradation
    • costd
      • Jan 2008
      • 409
      On the paper, this falls in the same line as wanting to put 2 tons of dirt in a 1/2 ton truck. Any time you try to go out of the design specs, not only do you void any warranty, you are asking for trouble.
      I suppose a service tech could mess with the nip and you feed single sheet at a time via the bypass, but as I said above, you would be asking for real trouble.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Because the stock weight is over the machine specs I'd do just that...try one sheet at a time via the bypass..WITHOUT the finisher if it has one.
        If it works...good for you...but remember...the machine isn't supposed to run that type of stock at all.
        • Ariflakhani
          Thanx
          Tried through the buffer pass,one at a time it worked but guess will stick with the specs....thanx anyways.
          • Ariflakhani
            Thanx
            thanx will stick to 250gsm
            • Ariflakhani
              will try
              thanx will try and see if it helps!!
              • Canuck
                Tech Specialist
                • 1713
                3380 in a print shop.....WHY.....this is a business color machine....even with an imagepass rip you wont get any pantone color matching. As for heavy stock...this machine is useless. You get what you pay for...only machine Canon supports for 300 gsm or 12-point paper is Imagepress v7000....You can buy 15 3380 machines for price of one V7000.
                • 10871087
                  • Jan 2005
                  • 1062
                  I hate to be a wise ass but, it doesn't work because it's not supposed to.
