I have just opened a small printshop today and have purchased a canon irc3380i...the spec says u can print stock upto 220 gsm the local tech said u can go upto 250gsm but i have a client who needs business cards on 300 gsm?Also am having difficulties in getting the correct or even nearest PANTONE shade am struggling in getting the colors right.
HELP PLEASE!!!
BLITZKREAGG
irc 3380i
as for the color issue have you done a full auto gradation in service mode
AF 28 AF > cleaning, adjustment, > Auto gradation -
On the paper, this falls in the same line as wanting to put 2 tons of dirt in a 1/2 ton truck. Any time you try to go out of the design specs, not only do you void any warranty, you are asking for trouble.
I suppose a service tech could mess with the nip and you feed single sheet at a time via the bypass, but as I said above, you would be asking for real trouble.Comment
If it works...good for you...but remember...the machine isn't supposed to run that type of stock at all.Comment
Ariflakhani
Thanx
Tried through the buffer pass,one at a time it worked but guess will stick with the specs....thanx anyways.
Ariflakhani
Thanx
thanx will stick to 250gsm
Ariflakhani
3380 in a print shop.....WHY.....this is a business color machine....even with an imagepass rip you wont get any pantone color matching. As for heavy stock...this machine is useless. You get what you pay for...only machine Canon supports for 300 gsm or 12-point paper is Imagepress v7000....You can buy 15 3380 machines for price of one V7000.Comment
