IRA C7260 empty waste toner message
  • copier tech
    • 8163
    [Misc] IRA C7260 empty waste toner message
    Right this may sound like a basic question but here goes, is this a customer replaceable item, its one thumb screw slide new bottle in etc but to reset the counter customer has to enter service mode? Or is there a reset in additional functions? 🤔
  • CS0523
    • Feb 2015
    • 35
    Re: IRA C7260 empty waste toner message
    I dont think that the customer should replace the bottle its not list as a consumable item for customer.
    I look in the e-manual and cant find an function to reset the counter. (I have only the e-manual, sry)
    • 20 year tech
      • May 2014
      • 577
      see attachedTP10 371a.pdf
      • copier tech
        • 8163
        Originally posted by 20 year tech
        see attached[ATTACH]41083[/ATTACH]
        Thanks! Maybe this is not available to us in the UK.
        Is there a part number for the label?
        • 20 year tech
          • May 2014
          • 577
          H
          ere is a PDF of it
          • Etech50
            • Oct 2017
            • 28
            This bulletin was for the 7000 series. The 7200 uses the same bottle but uses the reflector in the bottle to detect full not the window. There is a counter for waste but the message to empty comes from the sensor, not the count. If the customer is shown how to swap the full for an empty, that is all that needs to be done to get up and running.
            • julka123
              • Oct 2009
              • 37
              Hi
              Check this:
              WT-FL-LM Wst tonr full warning dis timing set
              Lv.1 Details To set the timing to display the waste toner full warning
              message. Depending on the user's use condition (image duty),
              the number of images to be printed until the Waste Toner
              Container becomes full is different. By specifying the image
              duty, the number of images to be printed until the toner full
              warning message can be set.
              If the image duty is approx. 10%, set to "1" since Waste Toner
              Container becomes full with approx. 120,000 images (B&W).
              Toner full warning message is displayed when the number of
              images reaches the setting value or when the Waste Toner Full
              Sensor is ON. If 4,000 images are printed further, the device
              stops.
              Use case When toner full warning timing is adjusted according to the
              Adj/set/operate method 1) Enter the setting value, and then press OK key.
              2) Turn OFF/ON the main power switch.
              Caution After replacing the Waste Toner Container, clear the counter
              using W-TN-CLR.
              Display/adj/set range 0 to 4
              0: Image duty: 30% (B&W 40,000 images)
              1: 10% (120,000 images)
              2: 5 to 7% (240,000 images)
              3: 3.75% or less (320,000 images)
              4: Not used
              Unit -
              Appropriate target value -
              Default value 1
              Required time -
              Related service mode COPIER> FUNCTION> CLEAR> W-TN-CLR
