Hello,
I am working on a IR3300 which initially was not moving paper beyond the clutch adjacent to the bypass roller. I checked and found out the clutch was stuck. After, I reassembled, the fans run OK upon turning it on. But the main motor does not run. It just start off and stops. Can anyone suggest something? Thank you for sparing sometime on this!
