canon irac 5051 E0075 error code
  • Jerrygbs
    • Dec 2008
    • 194
    [Error Code] canon irac 5051 E0075 error code
    I know this is a ITB belt that has run to the rear. My question is is the ITB displacement correction control adjusting constantly from front to rear or is it only adjusting when the displacement sensors PS 25-28 tell it to do so?
  • techandtrader
    • Jun 2016
    • 335
    Re: canon irac 5051 E0075 error code
    Basically yes. It runs to rear because it doesn't have the ITB improvement kit or it is old and/or has toner build up under the belt. Placing the belt back into position can buy 6 months on a low volume machine if conditions are not extreme yet. Make sure you do not generate extra service calls for this kind of maintenance. The customer will not appreciate it.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
    • Jerrygbs
      • Dec 2008
      • 194
      Im sorry I missed your reply but can you tell me what an ITB improvement kit is and is it a canon part , upgrade, or software upgrade
