Canon Ir400i /1730 fuser film not rotating
  • dk oneal
    • 12
    My canon ir 400i has poor fixing after replacement of fuser film. I suspect the grease I applied on the element is not compatible with (metal fuser films).the grease burns out and does not allow the fuser film to rotate
    Anybody knows which ( grease is best for metal fuser films) your suggestions are welcome .thank you all
    Sent from my GT-I9500 using Tapatalk
    Re: Canon Ir400i /1730 fuser film not rotating
    if you bought JUST the film.. it SHOULD have come with a lil packet of white grease. use all of it ..spreading over the metal n head. did you replace the rubber 'gear' on pressure roller? new bushings? what about the drive gears?
      • 22999
      I have always thought the amount of lubricant in the packet was stingy. I use Uniflor 8172 high temp grease for sleeves. =^..^=
        agreed BC... I caught some of my 'rebuild' guys trying to 'save money' and we ended up replacing them far too soon.
        never tried UniFlor before
          • 22999
          It's what comes with Precision Roller replacement sleeves. It's kind of expensive ... I think it was $65 for a syringe... here you go:
          Results for UNIFLOR
            Results for UNIFLOR
            thanks Brother!
            • dk oneal
              • 12
              Thanks bro ..the rubber 'gear and the bushings are ok .I think grease in the pack that comes with the sleeve is not enough .I think I need to try uniflor grease Blackcat talked about . Am a tech from west africa (ghana ) I need buy one .thanks so for your help
