error 602-001 error on ir-adv 8295
  • Arcadian
    • Feb 2010
    • 218
    for sst, i try cloning the drive, but no luck.
    thank for the help.
    Arcadian
  • vigour
    • Aug 2010
    • 1038
    Re: error 602-001 error on ir-adv 8295
    The hard drive on Advance series 2 machines have a factory password, which makes it impossible to do anything with them. They do not even show up as a drive outside of the copier
    • copier tech
      • 8149
      thank for the help.
      Arcadian
      Try simply reinstalling the SSW, create a firmware USB using the SST.
      • Ketchup
        • Jan 2019
        • 18
        There is a possible recovery process that Canon has bulletinized for the e602. Whats funny is I come from the Toshiba side, and their hdds are POS, and these are the same type. Let me know if you need the bulletin, but I think the damage is done and the post suggesting you do firmware is IMO the best option then replacing the hdd.
