Canon IRA C2225 with ghost images
  • doug
    • Dec 2011
    • 198
    Hi Guys!
    I have a church that has a "ghost image" on every copy and print in bothe B/W and color...
    I swithced all drums and ITB bet assembly and still the same result....any ideas?
    Thanking you all in advance,
    Doug
    Re: Canon IRA C2225 with ghost images
    Originally posted by doug
    Hi Guys!
    I have a church that has a "ghost image" on every copy and print in both B/W and color...
    I switched all drums and ITB bet assembly and still the same result....any ideas?
    Doug
    inspect fuser for damage/wear
    is it on the same side..same pattern ..maybe not in same spot but always equal distance? what is the MM spacing?
    provide pic?
    what is life count on parts and machine?
    • copier tech
      • 8236
      provide pic?
      Posting a print example would help.
      PG1 & PG10 for example.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5019
        1. cold environment
        2. Drum
        3. Drum cleaning brush
        • Brian8506
          • 1667
          Try switching out the fuser unit
          • dan7777
            • Dec 2012
            • 680
            Hi Guys!
            Doug
            Common problem. Usually a drum fixes it. The itb has a new style with instructions to change a few settings. I have been able to fix this problem by having them switch to letter R size from letter.. That model does not like generic toner either.
            • petermays
              • Mar 2017
              • 91
              hi.
              if you have replace the drum and you still having issues then you will need to check fuser.
              if fuser is ok then you might just need to do abit of cleaning on the HVT pcb unit.to much charge over drums
              • doug
                • Dec 2011
                • 198
                IMG_0234.jpg I have attached a sample of the issue as you have requested...any help would be greatly appreciated!
                Thank you Doug
                • guitar9199
                  • Sep 2016
                  • 1100
                  [ATTACH=CONFIG]41572[/ATTACH] I have attached a sample of the issue as you have requested...any help would be greatly appreciated!
                  Thank you Doug
                  Definitely looks like fuser to me.
                  • doug
                    • Dec 2011
                    • 198
                    V
                    Very good...I will go to the customer and try that.
                    I will let you know of the results!
                    Again, Thank you!
                    Doug
