Canon iRC2380i, waste toner box
  • helge
    • Jan 2019
    • 2
    - the machine iRC2380i doesn't work because of "replace waste toner box"
    - I replaced the waste toner box, then I replaced the optical sensor on the left side, but still it doesn't work
    - it seems the automatic reset after changing the waste toner box doesn't work
    - I think the sensor ps11 can't be the problem because of "replace ..."
    anyone an idea ? one of the boards out of order ?
  • teckat
    • 16092
    Re: Canon iRC2380i, waste toner box
    How to: Fix "Insert Waste Toner" - iRC2380/2880/3380 etc.
    • dan7777
      • Dec 2012
      • 680
      I had one doing that and the video is exactly the problem. I also looked at the optical sensor first. When you put the bottle in where the toner comes out is a sensor.
      • petermays
        • Mar 2017
        • 91
        hello
        there is a relay pcb in front.
        if you clean the sensor and problem is still there then relay pcb has blown.you will need to replace it.l
        • copier tech
          • 7931
          • helge
            • Jan 2019
            • 2
            I can't find the sensor, can you describe where it is (I think you don't mean the PS11, which indicates if there is a waste toner box installed or not) ?
            The problem is the message "replace the waste toner box", not the message "insert the waste toner box"
            • copier tech
              • 7931
              Look on the the waste toner bottle, there's a clear window that fills with waste when full & block the sensor giving the "replace waste toner" message.
              So to locate the sensor simply look when the little window fits in the machine that's the sensor, clean or replace it.
