So, I don't have access to firmware files for the irc C3080 that I have now in my possession, but I'm a bit worried about HDD failure in the future.
So I decided to get ahead of the game and image the drives so that I could rebuild them in the future if one fails.
imagePASS-J1
I successfully imaged the SATA HDD in the imagePASS-J1 that is attached at the back and I can run that up with a 2.5" laptop drive with the image written to it.
Since the imagePASS is Linux-based and is basically a custom PC, that was easy enough. Looks like I could probably put an SSD in there.
Copier Firmware
However, the HDD in the copier itself is an older 80GB Western Digital drive with an IDE interface. Does anyone know if transferring a disk image from the existing drive to an alternative would pose any problems rather than going the normal service route?
Is the copier fussy about the kinds of models I can put in there?
Rather than sourcing yet another "old" drive, are there newer SATA options that I could use if it came to needing a replacement (IDE/SATA adapter etc)?
imagePASS-J1
Copier Firmware
