Part # IR 550
  • vmx12
    • Sep 2007
    • 55
    Part # IR 550
    I have the parts list for the machine but not for the side paper deck. I need the # for the white plastic lever that controls the side paper deck pick up rollers. This lever is controlled by the sl101 solenoid. It's on the IR550 and probably the 600. Thanks in advance for any help.
    • 23010
    That's a Side Paper Deck-C1.
    I don't have the dreaded microfiche any more (and my eyes are just starting to uncross), but I do have this number:
    FG6-1631-080 Pickup Assy, Side Paper Deck-C1
    I don't know if its any help...... =^..^=
    • vmx12
      • Sep 2007
      • 55
      It's the lever connected to the sl101 solenoid. I have all parts lists except for the side paper deck. It's kinda "S" shaped but not really.
      • 20YRSEXP
        • 281
        I don't see a SL101 but I do see an SL1. Is the arm attached to the solenoid? I don't see a separate part for the arm. If it is attached the part number for the solenoid is RH7-5218-000. Now, I may be looking at the wrong part so keep that in mind. If you have any info to help clarify let me know. I do believe Blackcat is correct, it is a paperdeck-c1
        Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
        • 20YRSEXP
          • 281
          Please ignore my last posting, I believe I had the wrong parts manual. I do see SL101, part number is FH7-5827-000. But there is no arm showing in the picture even though it does show the pin. That doesn't make sense. So I hope this helps, but I have a feeling it won't If I can locate the arm # I will post again. Sorry
          • 20YRSEXP
            • 281
            OK, Yet another post. I think I have the number. FB3-9193-020. If the arm is slotted and not attached to the solenoid then the picture makes more sense. Hope I got it right this time.
            • vmx12
              • Sep 2007
              • 55
              Yes, it is slotted, sounds like the right one. Thank you very much.
              • 20YRSEXP
                • 281
                You're welcome, glad I could help.
