IRADV C5030 Jam Code 0206
  • RHodg57
    • Dec 2013
    • 191
    Experiencing jams 0206 fixing inlet stationary jam frequently on this 5030. Haven't seen this problem before.
    I am going to try switching the secondary transfer assembly since that inlet sensor is part of that.
    Any thoughts on this? When running multiple pages one page is almost out of the fuser, one is just before
    the fuser entrance and the 3rd just started to come out of the cassette. Sometimes can run 10 or more and no
    problem other times it jams every other page.
  • mc007
    reliable tech
    • Jan 2019
    • 28
    Re: IRADV C5030 Jam Code 0206
    check the fixing inlet sensor actuator may be its not actuate properly.
    • RHodg57
      • Dec 2013
      • 191
      It was the fixing unit. Swapped it out with one that I knew was okay. Just have to figure out why..
      Thanks for the help though!!
      • dan7777
        • Dec 2012
        • 680
        That is a stationary jam at fixing inlet sensor. Try another wrap on flag. Once I forgot to transfer the guide to new fixing roller. It jams with out it on and you can get it on backwards.
