0A02 power on jams Canon iRADVC2230
  • simon_NZ
    [Jamming] 0A02 power on jams Canon iRADVC2230
    Hi
    I am getting constant 0A02 jams from cassette 2. They are power on jams at PS17. Have run multiple copies without any jams but there are lots of jams in the jam log. Apparently it jams after printing or copying 2 or 3 pages (power already on) I cannot find any bulletins on this jam code.
    Thanks for any help if anyone else has seen this
    Simon
  • petermays
    • Mar 2017
    • 91
    Re: 0A02 power on jams Canon iRADVC2230
    hi.
    does your cass 1 work fine if so then its the ps17 sensor on the 2nd paper pick up unit.
    maybe the sensor arms movement doesnt move back fast enough.
    might be a mech issue inside the unit aswell.dont you have a spare unit to test with?
      manually check movement of sensor arms//flags.. any sticking? FIX
      run sensor test in SM.. any fail w. the manual test? REPLACE
      • simon_NZ
        Hey Phil, I checked sensor operation in IO in service mode and it turns on and off ok there.
        • simon_NZ
          Originally posted by petermays
          hi.
          Yeah PS17 is the sensor for pickup 2. I swapped pickup 2 and 3 over to see if the jam code changes or not as I didnt have a new one on me.
            Check harnesses.. check for opens or breaks
