Canon IR3025 Letters are getting scattered
  • samsingh04
    • Feb 2019
    • 7
    [Misc] Canon IR3025 Letters are getting scattered
    Hi,
    I am using canon ir 3025. While printing and taking xerox the letters are getting scattered. It happens in the middle of printing. I have attached the printed copies. Kindly help me.
    Re: Canon IR3025 Letters are getting scattered
    Originally posted by samsingh04
    Hi,
    [ATTACH=CONFIG]41730[/ATTACH][ATTACH=CONFIG]41731[/ATTACH][ATTACH=CONFIG]41732[/ATTACH]
    printing from computer?
    copy from glass?
    copy from ADF?
    IF PRINT
    what OS?
    What Driver?
    What type file?
    what version of word/pdf/wordpad?
    • samsingh04
      • Feb 2019
      • 7
      copy from glass?
      copy from ADF?
      IF PRINT
      what OS?
      What Driver?
      What type file?
      Yes I gave print from computer
      windows 7 Os
      Yes xerox from glass and adf.
      It is not the issue in computer or glass.
      I think it is the issue in inner parts.
      This scatter is not occured in all the pages. It only occur randomly.
      Kindly help me.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5017
        Hi,
        Printer require expert review.
        Old drum.
        Old developer.
        Non genuine toner.
        Pure contacts on developer,drum,door...
        Bad transfer roller.
        Bad fixing film....
        • techandtrader
          • Jun 2016
          • 335
          damp paper or worn out fixing unit. Actually I had that on Aftermarket toner many years ago. I vacuumed the dev unit. New OEM toner stopped the problem.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
            • 23010
            I'm with zoraldhino on this one. I think it's developing. Are you using aftermarket toner? =^..^=
            • Andyboachie
              • 185
              Old drum.
              Old developer.
              Non genuine toner.
              Bad fixing film....
              Do a stop test first: Enter copying process and shut the machine down just as the copy is about to enter the fuser unit. This will help you to either consider suspecting an error in the fuser or eliminating it from the probable culprit list. If it is a perfect copy than the picture you attached, then the fuser unit is the culprit. consider cleaning the fuser film with a strong solvent or replace it completely. If it is just as you attached before it enters the fuser unit, try the following:
              1. Try a working developer unit first
              2. If it continues, try a working charge roller
              3. If it continues, carefully clean laser unit's mirrors very well with clean soft cotton material or a cotton swab.
              I hope you get the solution for your relief!
                3. If it continues, carefully clean laser unit's mirrors very well with clean soft cotton material or a cotton swab. I hope you get the solution for your relief!
                well I think zoraldinho knows what to do..
                1) you should reply to the OP. zoraldinho IS not that person.
                2) i would take zoraldinho suggestions over yours.. seeing his expertise .. valid suggestions.. and how the problems you have requested help for could be handled by a properly trained tech of 2 years.
                56 posts .. -0- rep power awesome! snicker
                • Andyboachie
                  • 185
                  You are right with the direction of the reply. I just clicked "Reply with Quote" at the bottom. I'll someday get better above 56, learn how to score more rep power after knowing how to do it or maybe take if off completely. lol
