Canon IR3025 paper from first tray getting bend
  • samsingh04
    • Feb 2019
    • 7
    [Misc] Canon IR3025 paper from first tray getting bend
    In my canon ir3025, paper from first tray getting bend. i have changed the pickup roller yet the issue happens. i have attached the folded paper photo.
    Re: Canon IR3025 paper from first tray getting bend
    [ATTACH=CONFIG]41733[/ATTACH][ATTACH=CONFIG]41734[/ATTACH]
    look in paper path.. any blockage?
    what paper being feed..what size defined in job?
    guides too tight?
    jam codes?
    weight of paper?
    fine grain .. course?
    WHERE is it jamming?
    • samsingh04
      • Feb 2019
      • 7
      guides too tight?
      jam codes?
      weight of paper?
      There is no block in paper path
      I tried all size of paper A4, A4R, Legal.
      All papers are getting folded.
      No jam codes coming. It is getting delivered without error but the paper is getting fold.
      No jamming occur.
      It delivered with paper folded.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5011
        Sticky registration sensor.
        Sticky dumpers on the door. Remove all.
        • zoraldinho
          • Mar 2008
          • 5011
          guides too tight?
          jam codes?
          weight of paper?
          Sounds like my son when he was 3 years old. Why this? Why that?
          No offense, Phil.
          • dan7777
            • Dec 2012
            • 680
            I agree with this. I take the first paper feed assembly out to take sticky pad off. Pull on reg flag a little and if you push it and feel sticky then that is issue. Good call.
            • samsingh04
              • Feb 2019
              • 7
              I am a newbie. I don't know about Sticky registration sensor and Sticky dumpers. Can send me the photos of Sticky registration sensor and Sticky dumpers. Please..
              • roho
                • Mar 2009
                • 844
                I find removing those sticky pads actually cause folding, replace them!
                • samsingh04
                  • Feb 2019
                  • 7
                  Kindly send me the photo of that sticky pad please
                  • roho
                    • Mar 2009
                    • 844
                    Not possible for me, haven't had that model kicking around for a few years. If memory serves, open the right door and there is a flapper that is controlled by a solenoid, and it rests on two small foam pads. the foam becomes gummy, and causes jams, so techs remove them and causes dog ears.
                    Perhaps someone else has a one of these around to take a photo of.
                    • dan7777
                      • Dec 2012
                      • 680
                      Removing damper pads.pdf
                      • Kyaw Thu Ko
                        • Jun 2018
                        • 10
                        Dear,
                        Make a little bit straighten that steel bar.
                        if it bend too much, its push force make the paper fold.
                        0-02-06-0c04baef252b41871148acb130fbde7804f7c09922b10a8f3624dd3842cb209a_2e7b0079.jpg
