Canon IR2016J...HELP!
  • fefemusic
    • Feb 2019
    • 14
    #16
    Re: Canon IR2016J...HELP!
    sorry, but which cable should I unplug if a card reader is not installed?
    • nicknt82
      • Nov 2011
      • 155
      #17
      Originally posted by fefemusic
      I have identified the sensor under the drum .. Lowering the sensor the REG value is 0 .. Leaving the sensor the value is 1 .. So it means that it works?
      So, if it's good.Continue with next sensor. Try to change it's state
      • rapidocument
        Multibrands Tech
        • Jul 2012
        • 381
        #18
        Probably damaged board. Expensive.
        Change machine.
        My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • techandtrader
          • Jun 2016
          • 335
          #19
          Keep in mind the original paper assemblies in these were designed wrong. They were revised a few times and there was a tech pub about needing to replace BOTH paper feeds because the new design broke the timing on the lower cassette. Like said above, not worth your time or anyone else's time or money.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
