Ir 8105 pro wont print images
  • tinnyjay
    • Oct 2009
    • 663
    Hi,
    Today i faced a strange problem. Printer wont print images even main corona, fuser and developer unit are almost new.
    Happened at the same time from 3 different computers.
    Tried PCL, UFR2 but still the same, cleaned laser unit, cleared dc con and m-con(re-entered values) but no difference Photocopying its ok. Print text is so good
    I am attaching one photo and text. As you can see the logo of windows on the bottom page of printer test its faded.
    "Who loves the roses,must also bear thumbs"
    Re: Ir 8105 pro wont print images
    Originally posted by tinnyjay
    Hi,
    Tried PCL, UFR2 but still the same, cleaned laser unit, cleared dc con and m-con(re-entered values) but no difference Photocopying its ok. Print text is so good I am attaching one photo and text. As you can see the logo of windows on the bottom page of printer test its faded.
    [ATTACH=CONFIG]41863[/ATTACH]
    What is the driver set to print? TEXT or PHOTOS?
    what do the photos looks like?
    what type file?
    printed from what program?
    Info leaves a lot to be desired!
    • tinnyjay
      • Oct 2009
      • 663
      what type file?
      I tried General/PUblications/Graphic. Programs are MS Word, Adobe PDF, Nitro PDF, Print from photo.
      Also i tried Illustrator and Photoshop.
      Text written on computer is good no matter from wich program you print. If its a logo, photo, letter head, scanned docs i have the problem i said above.
      PS. I print from 2 different computers with Deep Freeze and one main computer (without deep freeze).
      • tsbservice
        Field tech
        • 8029
        Does this machine has internal test prints? If so print them, how do they looks?
        Sounds like software/driver or maybe print controller problem especially as you stated copies are fine.
        • tinnyjay
          • Oct 2009
          • 663
          You are right. Print controller was faulty.
          initialized printer and now its fine.
          By the way i made a deep clean of machine 😂😂😂
          Thank you so much,
          case closed
            • 23010
            Did you print from your laptop via crossover, with current drivers? =^..^=
