IRADV C5035 copy problem
  • safuanjafri
    • Mar 2017
    • 27
    [Misc] IRADV C5035 copy problem
    Hi, what problem actually occur when i copy 1 or 2 sides, the doc image is skew as attachment below.. i tried to to enter factory value in sv mode, adjust>feed adj but still wont work. Is this mechanical problem or just setting? This only happen when do copying or scanning. Print is fine
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IRADV C5035 copy problem
    Do you have a problem when using an adf or glass?
    • safuanjafri
      • Mar 2017
      • 27
      [QUOTE=zoraldinho;741108]When do you have a problem when using an adf or glass?[/QUOTE
      Using adf
      • zoraldinho
        • Mar 2008
        • 5015
        The paper does not travel smoothly through the adf.
        Check the paper path, check adf hinge, pickups ...
        • safuanjafri
          • Mar 2017
          • 27
          ok noted. i will try
