Canon IR 4025 Duplex printing Issue
  • raveendrala
    • Oct 2016
    • 80
    Hello
    I got Canon IR 4025 machine with paper jam at Duplex unit , .Please check attachment.
    Changed Side door,Connector , H
    arness wire side door to Engine controller And Engine controller PCB
    Any help would be great.
    Thank you​
    Re: Canon IR 4025 Duplex printing Issue
    Originally posted by raveendrala
    Hello I got Canon IR 4025 machine with paper jam at Duplex unit , .Please check attachment. Changed Side door,Connector , Harness wire side door to Engine controller And Engine controller PCB Any help would be great. Thank you​
    Have you checked door/duplex assm for burrs.. obstructions .. gears.. rollers.. sticking.. moving rough?
    why throw all those parts it until you knew WHAT was causing it?
    or have you NOT laid out everything you have tried?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Jam code?
      Are you a tech or user?
      • raveendrala
        • Oct 2016
        • 80
        Originally posted by zoraldinho
        Jam code?
        thank you
        • raveendrala
          • Oct 2016
          • 80
          I do not know how to talk with you, if you do not tell are you technician or user!?
          I" m tech and new to Canon
          • raveendrala
            • Oct 2016
            • 80
            I have one machine for parts , I check parts one by one below order
            Replace duplex assm
            Duplex clutch
            Thank you
            • zoraldinho
              • Mar 2008
              • 5015
              You switch complete door and still jaming? Hmm....Two bad doors? Probably humidified paper.
              How often is jammed? Each print?
              Try with turned paper Leter-R or A4 R. If worked change paper and set new values.
              Set fixing control temp table: curled paperService Mode > (LEVEL 2) > COPIER > OPTION > IMG-FIX > TMP-TBLC> Select "2" (N1 mode with plain paper 1/2 (target temperature becomes low.)) or "3" (N3 mode with plainpaper 1/2 (target temperature becomes moreover low.)).
              Set fixing control temp table: Thin (To use for thin paper setting)Service Mode > (LEVEL 1) > COPIER > OPTION > IMG-FIX > TMP-TBL5> Select "1" (S-thin paper mode (target temperature becomes low.)) or "2" (SS-thin paper mode (targettemperature becomes moreover low and lower the value of bias at the leading edge of the paper.)).
              Inspect duplex solenoid,clean and inspect duplex flag sensor,worn flags,broken flappers....
