IR advance 6255
  • buboy2222
    • Aug 2017
    • 13
    IR advance 6255
    I've been replace new scanner assembly for the error 302 - 0002. Scanning on the glass for 4 pages the machine ok. Scanning on the glass for 5 pages or more the machine hang up. Sometimes when scanning the scanner is on the middle and the light always on. Then the machine came with an error 302 - 0002.
    Any suggestion will greatly appciated
    Thank you.
  • teckat
    • 16092
    Re: IR advance 6255
    Thank you.
    Scanner cable
    Internal breakage
    • buboy2222
      • Aug 2017
      • 13
      Re: IR advance 6255
      Originally posted by teckat
      Scanner cable
      Internal breakage
      ir con of ir advance 6255 is the same of ir con ir advance 6075?
      • dan7777
        • Dec 2012
        • 680
        Re: IR advance 6255
        Thank you.
        If you put a new scanner in you could try the flat cable to it. Do the white level adjustment (I think there are 4).
