IR ADVANCE 6055 error E00355
  • mohd sadiq
    • 25
    Hai , now I am in India at my own city. Past two years I was not in field because of some personal works. Now I am starting again my own copier service . I am very glad to contact again. I replaced a used working main controller with existing counter and serial number PCB on IR ADVANCE 6055. before no power-on. Now machine is power-on but with Error E00355. How can I fix it. Need your advice. Thanks.
  • alex@wocltd.com
    • 430
    Re: IR ADVANCE 6055 error E00355
    possibly you cant - you need counter chip to marry with existing m/c and serial number.
    have you got the old counter chip?
    • mohd sadiq
      • 25
      Yes I put back the old counter PCB and serial number PCB.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4955
        In older models, you can reset the E355 in service mode level 3. On Advance series, I'm not sure.
        Practice makes perfect
        If you want something done right, you have to do it yourself
