Paper jam
  • Reeves
    • Apr 2012
    • 296
    [Jamming] Paper jam
    Hi I have a Canon ir5065 when I make single side its working okey but when I do double sided it always jam at the registration when it is going to do the second printing what could be the problem
  • Arcadian
    • Feb 2010
    • 218
    Re: Paper jam
    few things comes to mind, clutches, rollers, bearing in duplexer. are you sure its the duplexer?? sending one sheet only check to see if the sensors are clean by the transfer roller could be projecting a false jam there, lots of paper dust could be an issue. check those cluches, in the duplexer.
    good luck
    maybe a picture of where it stops would be good
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: Paper jam
      Jam code?
