Single pass ADF, front and back sides skew quite badly with 11x17. This machine is nearly brand new.
Adjusting the right hinge didn't change much. We have tried all the way front, to all the way back with half turns of adj screw.
ADF height was also adjusted on both sides with no noticeable change. We just chase it around.
A new tested and working ADF was brought out to segregate the issue. When installed on "problem" machine, it had the same skew.
Some right hinge adjustments on this ADF didn't make any changes either.
The strange part is, when the working ADF was brought back to its original machine, the skew came with it.
Same issue. Both sides skewed roughly the same amount. So now there are two ADF units with same issue.
Things don't add up. Makes no sense that front and back are skewed now (top side scanner was not touched at all).
Any ideas?
Anyone??
Havent reached out to Canon ISG yet.
Any ideas?
Anyone??
