ir adv c3330 Error code E302-0001
  • kstan268
    • Apr 2012
    • 85
    is anyone big brother encounter this Error before E302-0001.it happen when want to make copy or scan using feeder...press the start button it come out this error code and ask you to on and off the machine....i try to clean the glass and the scanner unit and ok for a while the come back again....what's wrong ???please help
  • disamm
    • Oct 2018
    • 59
    Re: ir adv c3330 Error code E302-0001
    302-0001 Shading error
    An error in the shading value was detected at white shading.
    - Harness between the Scanner Unit and the LED PCB (Unit of replacement: LASER SCANNER ASSEMBLY)
    - Flat Cable between the Main Controller PCB (UN05/J33) and the Scanner Unit (Unit of replacement: CABLE, FLAT)
    - Scanner Unit (Unit of replacement: LASER SCANNER ASSEMBLY)
    - Main Controller PCB (UN05) (Unit of replacement: MAIN CONTROLLER PCB ASSEMBLY)
    - Stream Reading Glass (Unit of replacement: GLASS, READER)
    Check/replace the related harness/cable, connector and parts.
    • Rachid.Akli
      • Oct 2011
      • 595
      Hi,
      This is common for this model. Replace the flat Cable between the Main Controller PCB and the Scanner Unit.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • kstan268
        • Apr 2012
        • 85
        Originally posted by Rachid.Akli
        Hi,
        Rachid.
        After replace work for few hour then come back the same problem ....Any idea need help
        • canon-korea-incheon
          • Apr 2019
          • 5
          1. Clean the four mirrors after disassembling the CCD.
          2. Adjust the numerical values after upgrading the firmware.
          E302발생조치_통합.pdf
          • kstan268
            • Apr 2012
            • 85
            [ATTACH]42437[/ATTACH]
            Thank you for your service info..my problem solve and no need to change any parts save money
            By the way you are from korea??? thank you very much again
            대단히 감사합니다.
            • cipinet
              • Jun 2019
              • 6
              Hello, today a have copier irc3325 with same error. Cleanned mirrors of scanning unit but no result.
              But with update, I think latest is 04.2022, error is gone.
              Error appiered only when use ADF, if use glass no error.
              • wcanonw
                • Aug 2014
                • 404
                Did you clean the ADF scanner?
