ir adv c3330 Error code E302-0001
  • wcanonw
    replied
    Re: ir adv c3330 Error code E302-0001
    Did you clean the ADF scanner?
  • cipinet
    replied
    Hello, today a have copier irc3325 with same error. Cleanned mirrors of scanning unit but no result.
    But with update, I think latest is 04.2022, error is gone.
    Error appiered only when use ADF, if use glass no error.
  • kstan268
    replied
    Originally posted by canon-korea-incheon
    1. Clean the four mirrors after disassembling the CCD.
    2. Adjust the numerical values after upgrading the firmware.
    [ATTACH]42437[/ATTACH]
    Thank you for your service info..my problem solve and no need to change any parts save money
    By the way you are from korea??? thank you very much again
    대단히 감사합니다.
  • canon-korea-incheon
    replied
    E302발생조치_통합.pdf
  • kstan268
    replied
    Originally posted by Rachid.Akli
    This is common for this model. Replace the flat Cable between the Main Controller PCB and the Scanner Unit.
    Rachid.
    After replace work for few hour then come back the same problem ....Any idea need help
  • Rachid.Akli
    replied
    Rachid.
  • disamm
    replied
    302-0001 Shading error
    An error in the shading value was detected at white shading.
    - Harness between the Scanner Unit and the LED PCB (Unit of replacement: LASER SCANNER ASSEMBLY)
    - Flat Cable between the Main Controller PCB (UN05/J33) and the Scanner Unit (Unit of replacement: CABLE, FLAT)
    - Scanner Unit (Unit of replacement: LASER SCANNER ASSEMBLY)
    - Main Controller PCB (UN05) (Unit of replacement: MAIN CONTROLLER PCB ASSEMBLY)
    - Stream Reading Glass (Unit of replacement: GLASS, READER)
    Check/replace the related harness/cable, connector and parts.
  • kstan268
    started a topic ir adv c3330 Error code E302-0001
    is anyone big brother encounter this Error before E302-0001.it happen when want to make copy or scan using feeder...press the start button it come out this error code and ask you to on and off the machine....i try to clean the glass and the scanner unit and ok for a while the come back again....what's wrong ???please help
