IPF8300 keeps replenishing with ink for 1 hour
  • silviu_25
    • Jan 2019
    • 27
    Hi all,
    my IPF8300 for some reason if I power on in normal mode keeps replenishing with ink for loong time and the only way to stop it is to unplug power source.
    In service mode I have no errors and everything is fine.
    Any idea what it could be?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: IPF8300 keeps replenishing with ink for 1 hour
    Clogged printhead or purge unit.
    • silviu_25
      • Jan 2019
      • 27
      Here is a nozzle check from service mode. 1 block is missing from R head, but a month ago when heads was ok and perfect nozzle check I had the same problem.
      About purge unit, what could go wrong with it?
      • smiley
        • Aug 2008
        • 615
        replace the print head. it will just throw all your ink. are you using original ink?
        there is no glory without sacrifice
          • 23009
          Ink Owl branded ink cartridges have caused this for me. The explanation I got was air leaking into the cartridges. =^..^=
          • silviu_25
            • Jan 2019
            • 27
            I'm not using original ink, and after many investigations I've decided it's the mainboard because 2f42 error.
            I sent it for servicing.
            • Canuck
              Tech Specialist
              • 1713
              Non Canon ink? Yup...this is what happens. I see it all the time. Save money on ink and ruin your printer/heads. Have cap absorbers been replaced? They gum up and the purge unit can't create negative pressure to pull the ink to the printhead..2F42 is not necessarily main controller. These machines need to have newest firmware in them. Old firmware plus old head gives a shorted printhead that fries the controller. If your route is main con, I would upgrade firmware, replace cap absorbers and install a new head if over a year old before I install that main con. I've seen old heads fry newly installed main cons...good luck
              • smiley
                • Aug 2008
                • 615
                i suggest if you used compatible ink use the printer daily. in my experience those ipf who print a lot get a longer printhead life than those who barely use.
                • silviu_25
                  • Jan 2019
                  • 27
                  Problem is solved now after I've sent the mainboard to a specialised centre to fix it.
                  Thank you all for all the info.
