Canon imagepress C7010
  • tbyabachwezi
    Engineer
    • May 2017
    • 24
    [Dead] Canon imagepress C7010
    Hi guys. I have Canon imagepress c7010vp when I turn on the main switch only standby LED on screen light, if I press power button nothing happened. I tried to check all power supplies it seems ok.
    Pls I need your help guys what could it be problem I'm ready to pay anyone who shows interest of helping
    Here is my email tbyabachwezi@gamail.com
    Regards
    Re: Canon imagepress C7010
    Originally posted by tbyabachwezi
    Hi guys. I have Canon imagepress c7010vp when I turn on the main switch only standby LED on screen light, if I press power button nothing happened. I tried to check all power supplies it seems ok. Pls I need your help guys what could it be problem I'm ready to pay anyone who shows interest of helping Here is my email tbyabachwezi@gamail.com Regards
    what do you mean by: I tried to check all power supplies it seems ok.
    HOW did you check them?
    did you use a Multi/Ohm Meter?
    if so.. what did you check?
    incoming/out going power?
    do you have a service manual?
    ARE you A tech?
    Phil B. " The Dentist"
    • tbyabachwezi
      Engineer
      • May 2017
      • 24
      ARE you A tech?
      Thank you for replying, yes I'm tech and I used multimeter to check +3v and fuse also I have service manual for the same machine.
        Just 3v? What controls OP?
        Motors/Solenoid?
        5v ok?
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          Turn off all accessories and try again. You know how to read the flashing light on the motherboard?
          • tbyabachwezi
            Engineer
            • May 2017
            • 24
            No any flashing lights on accept on main board-M buy it's not flashing it's solid red. Can you pls give me your email then I can call you thought Mobile?
            • tbyabachwezi
              Engineer
              • May 2017
              • 24
              [QUOTE=Phil B
              On top of that I have checked 5v going to DC controller 1-2 are ok.
              • wcanonw
                • Aug 2014
                • 404
                hello master zoraldinho I have a similar problem with an imagepress canon c6000, pressing the main switch button on the lcd panel, just turn on the main power lamp. when checking the part where the main board is there are some LEDs that are lit orange, but there is no sign that the motors, fans, fuser unit, etc. will be activated. of the printer
                • wcanonw
                  • Aug 2014
                  • 404
                  [QUOTE=tbyabachwezi;748840][QUOTE=Phil B
                  On top of that I have checked 5v going to DC controller 1-2 are ok.[/QUOTE]
                  hello how did you solve your problem with the imagepress c7010
                  • Setright
                    FSS / SPM
                    • Nov 2008
                    • 247
                    Hi !
                    This is just a suggestion: Check the handles on both fixer units. They must be locked into the correct position. Next, make sure BOTH the high and low voltage switches are being engaged when the handle is locked in place. The switches are at the rear of the machine, you can see them if you remove the rear cover.
                    I have seen the low voltage switches (microswitch) lose one screw and therefore not close when the handle is locked. This means the controller thinks the fixer is open and it will not switch on the high voltage circuits.
