iRADV8505 machine hang
  • Blues Guy
    • Aug 2009
    • 216
    Good day guys,
    I have a unit iRADV8505 the machine you can ON and ready to copy. But the panel LCD display seems like hang freeze and slow response when you try press a function on it. I suspect is the HDD problem and swap from a running condition machine but ERROR code appear E602-1401. Is it now for 3rd generation ADV machine the HDD you can't swap from 1 machine to another machine just like the serial number and counter ?
    Any way to get this problem solve...? Thank you guys in advance for your advice if any.
  • JPiek
    • Oct 2014
    • 435
    Re: iRADV8505 machine hang
    Not sure about the HDD swap, wouldn't suprise me though...
    But is it just the functions of the display ? If you manage to make a copy, doe that work normaly ? can you print normaly ?
    I know of the IRAVc52xx machines having a problem with it''s displays...
    Johan
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Or just a ctuck button.
      • JPiek
        • Oct 2014
        • 435
        btw. if you have a running machine (since you took out the disk from that one) you could easely swap the displays. It's not that difficicult..
        Johan
        • Blues Guy
          • Aug 2009
          • 216
          Yes we have try to swap the panel assembly but is still the same.( Is not panel display problem) . Further checking the machine can't perform copying it does not response at all. Try to go in to service mode just want to clear DC and MN Con to try out but it just no response.
          • zoraldinho
            • Mar 2008
            • 5015
            Did you try with self diagnostics?
            • Blues Guy
              • Aug 2009
              • 216
              You mean by pressing 2 & 4 together and power up the machine right ? Try that result is " OK "
              • Ketchup
                • Jan 2019
                • 18
                You can't swap HDD, can't remember what Canon calls it, but its mated to the system and you cannot put into another copier.
                • guitar9199
                  • Sep 2016
                  • 1100
                  Start simple....
                  Check for sticky buttons on the control panel. One key stuck down can confuse the machine.
                  Are they running Power over Ethernet?... That'll mess up the controller in your display. Disconnect the network cable, reboot and see if it starts responding normally.
                  ...good luck.
                  • canon-korea-incheon
                    • Apr 2019
                    • 5
                    If the touchpanel is slow to operate and the buttons are slow to operate, the CPU PCB must be replaced.
                    • Blues Guy
                      • Aug 2009
                      • 216
                      May I know which CPU PCB that you mention. Can specific which one ?
                      You mean the control panel assembly CPU ?
                      Thank you for enlighten me.
                      • Blues Guy
                        • Aug 2009
                        • 216
                        Hi guys,
                        Just update refer to the above machine problem we have solved it by reloading the firmware to the HDD.
                        Thank you guys who have give some idea early.
