IRC2880 A3 cassette Jamming
  • stefkpl
    • Sep 2017
    • 25
    [Jamming] IRC2880 A3 cassette Jamming
    Hi Guys,
    My IRC2880 jamming all paper size into the second cassette.
    I have checked paper size sensor, but it's look like dectection jamming too fast.
    The paper go out but it stop with no raisons (only jamming message) ...
    have you got any ideas?
    Best regards.
    Stef
    Re: IRC2880 A3 cassette Jamming
    Originally posted by stefkpl
    Hi Guys, My IRC2880 jamming all paper size into the second cassette.
    have you got any ideas? Best regards. Stef
    on the screen what is the message?
    explain this " The paper go out but it stop with no raisons "
    paper go out (of the tray?)
    but it stop (WHERE?)
    what are the paper tray size/weight/orient set for ?
    Please upload config page showing paper tray config & picture of the jam in the machine
    how many pages total on machine?
    what service has been done/not done?
    Phil B. " The Dentist"
    • stefkpl
      • Sep 2017
      • 25
      I'll take pictures of what's you want tomorow.
      Thank's
      • stefkpl
        • Sep 2017
        • 25
        I can't explain, all signals sames to be good, the paper go out and stop before arrive to PS 26
        It's the same probleme with all paper size and orientation.
        Compteur principal
        112 : Total (Noir/Grand format) 2431
        113 : Total (Noir/Petit format) 46743
        122 : Total (Quadrichromie + Monochrome/Grand format) 1059
        123 : Total (Quadri + Monochrome/Petit format) 16061
        501 : Lecture (Total 1) 28187
        301 : Impression (Total 1) 43258
        I think I must calibrate something.....
        • Andyboachie
          • 185
          [ATTACH=CONFIG]42497[/ATTACH][ATTACH=CONFIG]42494[/ATTACH]
          Compteur principal
          If the jam occurs before it gets to PS26, then it means just the lead edge go out, the full length of the paper does not go out right?
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            Start with new pickup rollers.
            Visually inspect inside cassette 2.
            Swap torque limiter with cass. 1.
            • stefkpl
              • Sep 2017
              • 25
              Sorry for my long time response, I had broken my LCD panel...
              The best is the enemy of the good :'(
              I think I have found the problem.
              If I push up the metal with the spring, it works.
              This is a know problem?
              How can I solve it?
              I had used the "Print Roller Cleaner and restorer" (Platenclene PCL 100)
              Thank's
              • stefkpl
                • Sep 2017
                • 25
                Have you got reference?
                Thank's
                • zoraldinho
                  • Mar 2008
                  • 5018
                  Different model.The same rollers.
                  Parts Catalog > Canon > iR4570 > page 30
                  • copier tech
                    • 8202
                    Your rollers are the old type very unreliable.
                    Replace the rollers with these part numbers:
                    FB6-3045-000
                    FC0-5080-000
                    FC0-6661-000
                    • stefkpl
                      • Sep 2017
                      • 25
                      Thank you guys :-)
                      • stefkpl
                        • Sep 2017
                        • 25
                        Re: IRC2880 A3 cassette Jamming [SOLVED]
                        It's ok, I received them, she's alive :-)
