Ir2030i scanning function missing
  • safuanjafri
    • Mar 2017
    • 27
    [Misc] Ir2030i scanning function missing
    Hi, guys how to restore scan function back?missing scan function maybe after i cleared ALL in sv mode. Anyone can help me pls
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ir2030i scanning function missing
    The scan feature on this model resides on a USB key attached to the image processor PCB inside the machine.
    • guitar9199
      • Sep 2016
      • 1100
      See image...
      • safuanjafri
        • Mar 2017
        • 27
        I already take out this usb from another working machine with scan feature, but still scan feature cannot be use in that machine. Any suggestion brother?
        • guitar9199
          • Sep 2016
          • 1100
          I'll need to locate my Canon Manuals. I'll check with the installation procedure, but I THINK there's a switch in Service Mode that might need to be changed... I'm going to need to verify though. Don't want to give you the wrong information.
          • copier tech
            • 8172
            When you did an all clear did you do a P-PRINT first!?
            Why did you perform this clear?
            • NexusTech
              • Apr 2019
              • 10
              if you change boot rom or hdd or counter this is problem-
              why you perform this clear??
              • safuanjafri
                • Mar 2017
                • 27
                Ok brother, thanks for your support.. i'll wait for your information
                • safuanjafri
                  • Mar 2017
                  • 27
                  Before scan feature missing, i got some problem which is when i started the machine, the machine always shown ''connection to PC is complete'' need to restart a few times then the machine ok. That why i try to clear ALL in sv mode to see if any different.
