can't print via LAN cable
  • guitar9199
    • Sep 2016
    • 1100
    Re: can't print via LAN cable
    Originally posted by JPiek
    Yes it is ! Nowaday's the crossing is done internaly in the laptop. I use a straight cable all the time..
    Try the next thing :
    - Shutdown copier
    - connect a laptop with it's Ip set to 172.16.1.1, netmask 255.255.255.0
    - press and hold no 1 and 7 on the copier, switch on copier, hold both keys until copier is booted and msg "Fixed IP" apears on the screen..
    - ping 172.16.1.100 from the laptop
    if that works
    next :
    open a browser and enter 172.16.1.100 in the adress bar, you should get the copiers web interface
    If that works
    next :
    install new printer - TCP/IP on 172.16.1.100, install correct driver
    print testpage..
    Ethernet on fiber-optic cabling still requires a crossover cable between two like devices, even at gigabit speeds. What you're describing only applies to UTP wiring.
    • JPiek
      • Oct 2014
      • 435
      You started about a straight Cat5 not working
      Besides, how do you connect a copier using fiber optic...
      Just trying to help out here...
      Johan
      • guitar9199
        • Sep 2016
        • 1100
        No worries... I've just never had any success connecting PC>MFP without using a hub or crossover. I know tech changes quickly, so you're probably right about not needing crossover anymore due to Gigabit Ethernet...I just try to err on the side of what I know works out of the chute.
        With Fiber ethernet becoming a "thing" now, it's likely we're ALL going to have to change our methods. I'm betting it'll be similar to having to "dumb down" fax features on copiers to work with VOIP phone lines.
