How can i change ADF form LTR to A4 ir2535i
  • xamky
    • Jun 2019
    • 22
    i am from thailand
    my ir2535i it japan spec ADF run only LTR when i put A4 can print only LTR area.
    thank you
  • teckat
    • 16092
    Re: How can i change ADF form LTR to A4 ir2535i
    Originally posted by xamky
    i am from thailand
    thank you
    ____________
    Service Mode>SCAN>SCAN READER>OPTION>BODY>SENS CNF = 1
    Power cycle machine.
    To make the value of SENS-CNF stick after the Copier is rebooted, the following needs to be set in service mode.
    SCAN > SCAN SW > SW06 > Bit2 to 1
    Also, to enable the correct paper selection, change the following setting of the paper size
    group.
    SYSTEM > SYSTEM Numeric > 057 to 3 for inch configuration
    Or in your case, select #1 for AB
    1: AB configuration
    2: A configuration
    3: Inch configuration
    4: AB / Inch configuration
    • xamky
      • Jun 2019
      • 22
      Dear teckat I try step by step but not work. may i do something mis or my MC damage.
      group.
      1: AB configuration
      2: A configuration
      4: AB / Inch configuration[/QUOTE]
      Damaged
      • xamky
        • Jun 2019
        • 22
        every body
        Please advice.
        need help.
        • xamky
          • Jun 2019
          • 22
          i am from thailand
          thank you
          Dear every body
          I have the way to fix this. But may not correct 100% but it work on every vertion MC.
          1.Choose Malaysia
          2.pull out conecter of A3 paper on ADF
          • teckat
            • 16092
            every body
            Please advice.
            need help.
            Related Service Mode:SCAN > READER > OPTION > USER > SIZE-DET
            <Setting value>
            0: The original size is not detected.
            1: The original size is detected.
            1. SCAN > SCAN SW > SW06 > Bit2
            Set the value to 1 about the above service mode, and then turn the power switch to off
            and then on.
            2. SCAN > READER > OPTION > BODY > SENS-CNF
            <Setting value>
            0: AB configuration
            1: Inch configuration
            2: A configuration
            To enable the correct paper selection, change the following setting of the paper size
            group if necessary.
            3. SYSTEM > SYSTEM Numeric > 057
            <Setting value>
            1: AB configuration
            2: A configuration
            ■■FEEDER
            ●●(#SCAN> FEEDER> ADJUST> DOCST)
            Adjusting the original stop position for ADF pickup (original tray pickup).
            Delivering the original enables the setting. Be sure to press the OK key to deliver the original.
            When changing the setting, input the setting on the main station service label.
            The larger the value, the smaller the leading edge margin.
            ●●(#SCAN> FEEDER> ADJUST> LA-SPEED)
            Adjusting the original feeding speed in stream reading.
            Use this mode to adjust the original feeding speed in stream reading mode.
            The larger the setting, the faster the speed (the image reduced).
