Machine is running blank copies when Using document feeder! It Seems be intermittent.
Canon Image runner advanced c5235
Re: Canon Image runner advanced c5235
Copies fine from the glass! will feed through the feeder and the output will be blank! Reseated the doc feed connections and checked ribbon cable scanner and made sure scanner stops under narrow glass, ok! I suspect reader controller but not sure! Seems to be fine now, the customer says the problem is intermittent!Last edited by acsolutions; 06-10-2019, 09:35 PM.Comment
