Canon IR7086 - print quality very light/faint
  • Curiouswof
    • Mar 2019
    • 4
    [CQ] Canon IR7086 - print quality very light/faint
    Hi folks,
    Good day!
    Recently I have encountered an issue where my print/copy are really light/faint. I have attached the above file where you can see the print that I mean really light/faint.
    Just to give a summary on what I did after this problem existed;
    1) The developer pictures which is the result after I tried vacuum once and after adjusted the doctor blade, the result doesn't change.
    2) I tried to turn on and off the potential control, when i off it, it looks much darker but it is not the solid dark that I want.
    3) I also adjusted the developer speed, it makes the print out slightly darker but still not the result I looking for.
    Let me know if you still need any further information and million thanks for your advice.
    Regards
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 276
    Re: Canon IR7086 - print quality very light/faint
    Originally posted by Curiouswof
    Hi folks,
    Good day!
    Regards
    Did you try to change the toner or swarp dev units?
    Also try to adjust the primary charger.
    • Curiouswof
      • Mar 2019
      • 4
      Thanks for the reply. Truly appreciated it.
      I didn't try to swap the developer units because I dont have an alternative. I will try to swap the toner. But before that, can i know how to adjust the primary charger?
      regards
      Alex
      • Curiouswof
        • Mar 2019
        • 4
        Any kind soul that willing to guide me on this issue?
        • Arcadian
          • Feb 2010
          • 218
          regards
          Alex
          i would just swap out the developer powder, look at the coronas, make sure there is no toner on them, wipe gently with some alcohol with a qtips on the wires but my bet would be the transfer belt or developer powder.
          Good Luck
          Arcadian
          • techandtrader
            • Jun 2016
            • 317
            There is a lot of info here about light quality on the 7095 . Some came with bad laser units. NWRS can send you a refurbed laser. In the service manual there are instructions to check for certain values in SM. This alone can confirm a faulty laser unit.
            I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
