Yellow colour is missing when printing on Canon IR Adv C5235
  • jacob234
    • Jul 2019
    • 11
    [Misc] Yellow colour is missing when printing on Canon IR Adv C5235
    Hello Dear All,
    I have problem with my copier Canon IRA C5235 where the yellow color or the picture contents yellow will not printed on the paper. I have select mode one color, that is yellow, the result is blank meanwhile for other such cyan, blue etc is ok.
    I have already replaced new yellow developer than the result is still blank. I also check in service menu by pressing *28* then check for the part check, the result is ok. I found some thing wrong when go to Function, Misc-P--> Misc-P --> AT-IMG-X reported NG!
    Re: Yellow colour is missing when printing on Canon IR Adv C5235
    Originally posted by jacob234
    Hello Dear All,
    did you clean the toner supply area?
    did you verify that the laser is working...
    so little info .... too many questions
    PhilB " The Dentist"
    • MunsterTech
      • Sep 2014
      • 380
      check the coupling on the yw dev assy, its like a mini propeller , they can break or come loose so you get no drive to the dev
      • copier tech
        • 8132
        I agree, take out the process unit, check the Yellow dev drive coupling compare it to the other drives they do break.
        • jacob234
          • Jul 2019
          • 11
          Dear PhilB,
          Did you mean hoper and botle base assembly area? I did not clean this area. It's look clean.
          I checked laser by pressing *28* then ---> System level 2 ---Laser then LD-ADJ-Y then i heard sound indicated laser was working then the result is OK for each color.
          -----System level 1 ---> DPC--> DRMSETY ---> OK others are OK
          -----System level 1 ---INSTAL-INISETY check developer --->OK
          -----System level 1 --->MISC P--> AT-IMG-X ----> NG!
          I did for followings,
          Replacing new Y developer --> yes
          Replacing new opc drum --> Yes
          Replacing new belt transfer ---> Yes
          • jacob234
            • Jul 2019
            • 11
            Dear Friend,
            I check the developer by using *28* System level 1--INISETY--Check developer the result OK. Then I open process unit, I saw toner go down to developer and this new developer has yellow toner at magnetic roller.
              Dear PhilB,
              Yes everything from bottle to dev inlet.. it might seem like its putting toner in dev..may not be enough
              .def check gears on dev as others have said.
              Does yellow show on belt if you do a stop test?
              • jacob234
                • Jul 2019
                • 11
                Dear Friend,
                Before install new developer, I did not se any yellow color or magnet powder onf magnetic roller sruface. After install it, and do intial developer in service menu (*28)* tehe resuli--> ok. I open process unit then I saw the all surface of magnetic roller filled by both magnetic powder and toner be spread evenly ( proportional). I diassmbky the developer to check coupling then comapre with another deveoper, It same and trying to rotate it, developer's coupling work properly.
                • jacob234
                  • Jul 2019
                  • 11
                  Dear Friend,
                  I di not see yellow on belt but I see on developer and drum area
                  .def check gears on dev as others have said.e
                  • jacob234
                    • Jul 2019
                    • 11
                    I have checked the coupling, there is no broken and work properly
                    Dear Friend,
                      Dear Friend,
                      did you do a STOP test ( half test )
                      you have to do it while machine is trying to lay down toner on page
                      • jacob234
                        • Jul 2019
                        • 11
                        How to do it? Could ypu please advisee me step by step?
                        • jacob234
                          • Jul 2019
                          • 11
                          Dear Friend,
                          I have already do test page half then no yellow
                          Dear Friend,
                          • ncbabak
                            • Apr 2014
                            • 43
                            Dear Friend,
                            Hi
                            If Yellow toner is on drum but it is not on transfer belt ,
                            it means toner cant transfer from drum on transfer belt,
                            and it may be cause:
                            1-Yellow primery transfer roller inside Image transfer belt
                            2-Charging High voltage of Yellow primery transfer roller
                            3-DC Controller board
                            Check them
                            • jacob234
                              • Jul 2019
                              • 11
                              If you do not mind, could you please advise me the part number?
                              Originally posted by ncbabak
                              Hi
                              Check them
