First I would like to thank you for your help!
I did the dc clear
and yes the "brush" on each unit looks good.
Keep in mind It will copy a b&w just fine even a solid bk
Its the color . now the Y has done a test dens with full coverage.
but the C and M start somewhat but serious void about 3 in into it.
The pattern looks like a beach with small water mark ripples and going to white.
same for both C and M
The prim wire and grid look OK and that would not print B&W if bad as far as I know.
and yes the toner on each color look well blended and brush.
the Y will print the whole page but not the C or M.
The M starts but some hard banding and uneven then into that beach effect and looks as if the toner just wont get off the dev unit.
I just dont feel as if its the patch sensor.
I did a ck on the shutter for it and watched it work as well as the atr flag.
but the display dens will show the default # on the dens and sgnl
but then print and error shutoff and the dens settings on display back to 0
I really think theres something going on with the dev units C am M just not getting the proper toner on drum then 0000020 error.
or the patch sensor for the K and Y is ok but the C and M not.
well I now know enough to tell a good tech like you whats up
Shur would like call you .
ill see if i can pm you my # if its ok.
thanks again
I did the dc clear
thanks again
