Iraddv c2220 image ghosting
  • safuanjafri
    • Mar 2017
    • 27
    [Misc] Iraddv c2220 image ghosting
    Hello guys, my iradv c2220 had ghosting image. already do reg-clr,clean laser unit,clean patch sensor, remove all drum,itb,laser and do color mismatch and auto gradation. the problem still exist. drum life still below 50%. any other suggestion to solve this? below is sample print PG10 & PG6
    Re: Iraddv c2220 image ghosting
    could be drum ..
    i'd look at the life and wear on the fuser
    • copier tech
      • 8172
      Do a DC Con clear if this doesnt help replace the ITB.
      • safuanjafri
        • Mar 2017
        • 27
        could be drum ..
        Noted. Will try. Ty
        • safuanjafri
          • Mar 2017
          • 27
          Noted.will try. Ty
          • safuanjafri
            • Mar 2017
            • 27
            Solved by replaced ITB. Ty so much
