Canon IR3380iADV Won't Boot
  • Andyboachie
    • 185
    Hello,
    A customer invited me to his IR3380i that cannot complete booting process.
    After Power-On, the sound that comes show progress in power cycle. But all I see is the bar that shows the progress stops about 3/4 to completion on the control panel.
    According to him, this happened after power outage. I removed and reseated the DIMMs, replaced the hard disk, I changed the cable that connects to the reader control PCB, all to no avail.
    Is anyone familiar with this kind of problem and what was the solution?
    I'll be grateful for your kind suggestions. Thanks in advance
  • copier tech
    • 8236
    Re: Canon IR3380iADV Won't Boot
    Originally posted by Andyboachie
    Hello,
    After you replaced the HDD did you reinstall the system software?
    Canon's boot up from the hard disk similar to a Windows PC, if this software is corrupt the machine wont boot up.
    • Andyboachie
      • 185
      Yes, I did that but the progress bar still stuck, so booting could not continue.
      • fchu5959
        Field Engineer
        • Jun 2010
        • 100
        Try to replace the DIMMS.Both at the same time.
        • Andyboachie
          • 185
          Thanks a lot!
          Replacing DIMMs solved the problem.
