IR3300 Laser Unit
  • princepriyu
    • Jul 2025
    IR3300 Laser Unit
    Please Check the image
    i just need to know about the use of these two registers on circuit board of Laser Unit (Canon IR3300) photocopier machine
    can we make any any adjustment to make the print quality Dark or light.
    I am having a normal laser printer HP1020 there is a same type of variable register on its laser unit.
    by making a adjustment on it by rotating it clockwise
    i had used it to improve the quality of the print on it.
    can we adjust any thing the quality or fineness or sharpness of the print quality by using these registers
  • Brian8506
    • 1664
    Re: IR3300 Laser Unit
    If the copier isn't making good copies, there's something wrong elsewhere. Condition of drum, adjustments to dv bias even though I wouldn't recommend that long term, dirty optics, bad toner etc. I wouldn't ever consider making adjustments within the laser.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4676
      Proceed with caution. Turning pots will just cause you more trouble! As other poster said there is something else causing your quality issues. Could be many things with machine being 20 yrs old, but I would start with the drum & developer unit. Remove all the toner from dev unit & hopper and vacuum real good, scrub mag roller with a scotch brite pad, then clean roller with alcohol, install a new "genuine canon" toner and that should darken up print.
      Also check if the slit glass and / or optics are dirty, this will give you light pages.
      • princepriyu
        Thanks all for the post
        everything is absolutely fine
        printing good, dark etc
        just out of curiosity i was asking that
        i had recently adjusted that kind, on my laser printer (HP Laserjet 1020)
        so wanted to give a try on a bigger machine (IR3300)
        thats why i thought consulting experts like you all is better than "TURNING POTS on my own"
        • ss200222
          • Jan 2012
          • 21
          Hi,
          Can someone please tell me if the Laser Unit of Canon iR3300 is repairable?
          Though i've replaced with another one, but would like to repair the older one, had error number E100.
          REGARDS.
          • Brian8506
            • 1664
            Nationwide in Kansas still repairs them
              Originally posted by ss200222
              Hi,
              REGARDS.
              you will need an O scope n other test pieces
              same if you repair monitors
                • 16374
                And a schematic would be most useful. It's been my experience that it's too much time involved to repair most circuit boards (unless they're simple) and soldering & de-soldering has become increasingly difficult due to the tiny nature of some micro-chips. You really need a lot of specialized equipment.
                I spoke with one of the guys at Hytek and he told me that they have some kind of diagnostic machine that they plug the board into and it identifies the problem in most cases.
                • Brian8506
                  • 1664
                    yes that machine has a wire harness and vacuum seals the board to the 'jig'.. then they press a button to start the diag process. My first ex-wife worked on the testing line at Memorex Telex and she alone could run test on 10 boards a day from the manufacturing line. If they pass it went on to assembly .. if it failed the machine would automatically print out a report pin-pointing the component(s) that failed.. then they would remove it and send it back thru the 'pick-n-place' machine, replace the defective part(s) and the process was started all over again.
                    Most times the surface mounted item had slipped out of it's spot before it hit the wave solder bath.
                    We manufactured Monitors... PC's,, modems .. dumb terminals and test equipment items for the service engineers in the field. I left MT in 1989 after working there for 13years in Stock room and Inventory Control where I was the manager of the Inventory Control team of 15 girls/guys.
                    It was a 65,000sq foot facility not including the three off-site warehouses.. Inventory time took 3 weeks from start to finish. depending on which section of the facility we could be in lockdown not allow out of the building. We had showers and a full restaurant that served 3 meals a day + snacks... 2,900 employees.
                      • 16374
                      You have a vast knowledge, sir. Well done.
                        I'll be 64 in February... been working since I was 14..that was at McD's.. I also owned my own lawn mowing service at 12... by the time I left MD I had taken on a partner .. employed 12 guys to do the mowing ..Bob Austin and I repaired small gas engines .. we lent out our mowers for the guys to use and took a cut of the monies for us. I sold Bob the business for $2,400 in 1977 ( I was still working at McD's as Maintenance Mgr at the store with 2 others in my charge ...)
                        you do the math ;-)
                          Alternatively, supply power to the board and using a thermal camera identify which component heats up abnormally. A few YouTubers I watch make a living fixing phones using in some cases this method alone but they need specialist equipment. However, this board in question from a twenty-year-old machine could be hand soldered by someone competent.
                          Could be just dry joints.
                            • 16374
                            Yeah, I've seen the thermal camera used on YouTube. It's cool as hell.
                              • 16374
                              Back when I was in electronics school we would use a logic analyzer, logic probe and an o-scope with data capture feature to troubleshoot most PC boards.
                              I remember an old trick when all else has failed. I've tired it with varying results. But I was just playing around on some old TV's. I don't really recommend this. You can put the PC board in an oven for about 5 minutes and sometimes it will work if you have a cold solder joint and can't find it.
                              Anyone ever heard of this?
