IRADV 6055 GOT BOLD STRAIGHT LINE WHEN PRINTING, intermittent ONLY
  • safuanjafri
    • Mar 2017
    • 27
    [Misc] IRADV 6055 GOT BOLD STRAIGHT LINE WHEN PRINTING, intermittent ONLY
    Hi, anyone had counter this problem? the printing got some bold/jerking font when printing,intermittent only... not continuosly. can check sample print below as attached document. i do really appreciate if any can helps me.
    • 22999
    Re: IRADV 6055 GOT BOLD STRAIGHT LINE WHEN PRINTING, intermittent ONLY
    I can't tell you exactly what's causing it, but that's a compression blur. The paper was traveling slower than the image on the drum.
    Several things can cause this:
    The paper may be slipping against the registration rollers.
    You may be losing drive to registration rollers
    More likely the fuser is turning slightly slower, buckling the paper away from the drum as the trail edge is released from the registration rollers.
    So that gives you three things to look at. Start with the last one. =^..^=
    • safuanjafri
      • Mar 2017
      • 27
      thanks for the guide. i will try this step
      • tsbservice
        Field tech
        • 7986
        Like BC said, check the last one. I would start with trying different paper formats and with trying to change paper settings to thick one, this will reduce processing speed and eventually match speed. If fine adjustments of Fuser speed is available on this model I will give them a try also.
        • Brian8506
          • 1664
          • safuanjafri
            • Mar 2017
            • 27
            Solved the problem, registration roller problem.. to slippery. Thanks guys for your help.
