canon ir3320i paper jam at rightside cover
  • brucestc
    • Aug 2019
    • 3
    [Jamming] canon ir3320i paper jam at rightside cover
    hi,my canon keeps jamming. the jams occur at in the right side cover, just below the bypass tray. bypass works just fine, no error code. those papers that made it to the output tray are often times folded. i ve cleaned all the four sensors of the four feeder cassette units but it didn't help.
  • Brian8506
    • 1658
    • brucestc
      • Aug 2019
      • 3
      Re: canon ir3320i paper jam at rightside cover
      no jam code. i ve changed pick up rollers but still jam wont stop
      • copyman
        Owner / Technician
        • Sep 2005
        • 4511
        Think it was this model, there are foam pads on a gate on side door that break down and gate sticks.
        • roho
          • Mar 2009
          • 844
          Had one tech who would remove the foam pads, usually led to folded edges. If you cannot replace these pads you can use electrical tape to cover them as a test or temp measure. The tape keeps the positioning of the flapper and takes the tackiness away.
          • brucestc
            • Aug 2019
            • 3
            where are the foam pads located? cant see any foam.
            • roho
              • Mar 2009
              • 844
              • Brian8506
                • 1658
                • roho
                  • Mar 2009
                  • 844
                  Me Bad, I will show myself out!
